i dont know
hello there!
i have a problem with my renders in v.10
i used to create walls in earlier versions with the surface whitewash material
and it was really good white and bright.
now in v.10 i think that my walls are too dark!
10 Replies 10
Dwight
What light /sun intensity are you using?
What Ambient?
What Hellezon (Undersun) setting?
Dwight Atkinson
What Ambient?
sun 80
ambient 60
camera 100
the other thing you say i dont know what it is
(why i didnt get an email for your answer? )
First of all before seeing your details i realised this building is in Greece.We are the only people that have that kind of buildings in Europe.... .Our legislation is so bad that forces us to make non orthogonal buildings when the land is not orthogonal.Anyways the best thing to do my friend is play with the material settings and cange the reflection ,emission and glowing parameters.Try different combinations to find the right one.As dwight said seee your light settings as well.You will find the solution...Im sure...
yes of course. but i think that you didnt understand what i said.
the thing is that this material was very nice in v.9 and i dont know why it changed. thats all
thanks anyway ill try to modify it.
Sorry Vivh I thought you didnt know how to change that.Obviously they ve changed the materials settings!Ha ve a nice day in beautifull Veroia!
WENDY_NEVERLAND wrote:
What Ambient?
sun 80
ambient 60
camera 100the other thing you say i don't know what it is
(why i didn't get an email for your answer? )
I think Dwight is going to cry What Dwight means with "Hellezon" is an extra sunobject that shines from beneath. (Yes I payed attention in his seminar)
Check the "set sunposition manually" box
If I'm not mistaken it's sunaltitude should be set at -90 and intensety at 35.
Be shore to set cast shadows off. (it will make the light shine through everything, especially the mesh )
If it's not clear I hope Dwight will correct me If you are rendering a lot I recommend his book about Lightworks
By the way: have you tried to change the emissioncolor to a brighter color?
i he comes in veroia ill go to but for now i think that i have to buy the book!
ill try all these you said . thanks a lot
thanks a lot mr. Kritike! you have a nice day too !!
Dwight
Put sixteen guys together and i'm there. But in the autumn.
Dwight Atkinson
