memory not enough to render the model (Bug?)
Hello
I have problem, when I render my file. It is show the warning like the subject, I wrote. I used computer HP XW 8400, 4 Gbs Ram. It doesn't work. It did warning memory not enough. I didn't understand. I have test with MacBook. It worked. Does the ArchiCAD PC do not compatible? How can I solve it? If I don't change to Mac.
How can explain me ArchiCAD how to use hardware? I mean use CPU, RAM and Displaycard.
Thank
wichai
Djordje
Windows XP 32bit?
The problem is in the LightWorks rendering engine, that needs more than 2GB RAM that is allowed by Windows XP.
You will have to render that model on the Mac. Not sure whether XP 64bit will allow you to do it. Search the Talk, there has been a thread about the same problem.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
