"Not enough memory" message while rendering
how am i able to do a rendering without the "not enough memory" archicad pop up from appearing, even if my computer has 2 GB of free memory.
13 Replies 13
You're welcome. Hope it helps. Could be the 2GB of RAM is hurting you.
And, of course, turning layers off is a nice alternative to deleting things.
For your signature, could you copy the info that you posted here, and paste it into your profile? Click the blue text Profile link near the top right - the signature field is near the bottom of that screen.
Just visited your website, and have to say that I really want to hire away one of your staff members. Give Murdoch a treat from me. 😉
Of course there is another solution - use an external renderer!
If you use Artlantis you can get it working for free for 30 day trial - if you enjoy it you might have just justified buying it. Artlantis is so very easy compared to lightworks...
Maxwell is another but I would not recommend it as it is so slow to learn you will run out of time in the trial period!
Thomas Holm
And Josh, upgrade to 12. There's a great performance difference.
Thank you everyone!
I will post some results as soon as I can work through it.
