reflection in sketch rendering engine
I created som renderings with the sketch engine. I wonder why I find some refelctions of door frames etc in the bottom, like shadows. Actually I didn`t find a way to avoid them. Do you have any idea?
Jens
4 Replies 4
Ben Odonnell
Jens,
Did you turn off you vectorial sun shadows? If so and you are still getting shadows, may be you sett all of the line settings, under shadows, to 0.
See the attached image
HTH,
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Hi Ben,
I don´t like to avoid the shadow. I just don't like the reflection of the door frame at the bottom. this looks like something like a shadow of the doorframe in the shadow of the building. the way you told me I do not have a shadow at all.
Sorry, if you didn`t understand me.
Jens
Ben Odonnell
Jens,
Not at all I am the one who didn't read it well enough. Well I have to go back to the drawing board and see if I can find the problem.
Cheers.
Ben
Ben O'Donnell
Ben,I found the solution: You can choose in the door settings, whether the the shadow of the door is visible or not in the 3D.
Very easy....anyway thank you.
Jens
