saving a photorendering favorite?
Hi, I am attempting to save a sketch style as a photorendering setting so my boss can select it and print perspectives without having to adjust the over stretch, line thickness etc. every time. (we are working in 14)
is there a way to do this?
thanks
3 Replies 3
It is a known limitation that the sketch settings cannot be saved. However it is possible to manually add your own settings to a preference file. If you post or PM a screenshot of your sketch setting dialog, can I post you guidelines how to do it.
Possibly this matter has been discussed before here in the forum too.
Hope this helps.
you cannot save it into favorites, but when you save a 3D into a view, the settings are stored. You can do this in a template so you only have to double click a view,
thanks so much that works great!
