Visualization
shadow diagrams
When I cast shadow in axo view at particular times, I get an irregular shaped shadow cast on the building - like an irregular shape is floating in space in front of the sun/camera. What is this and how do I remove it? Thank you archicad 17.
Katalin Borszeki
Hi, All
There are significant changes in the code for "shadow casting" between AC 17 and 19.
For understanding the problem, we have contacted the user for a file, but have not heard back so far. Best,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
Dear Katalin,
My apologies, I have now emailed directly with a dropbox link since the file is large.
Thank you for following up on this issue.
Kind regards,
Luisa
