Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Render your model with built-in or 3rd-party solutions
shadow issues
ok...now the shadow issues are back...any help?
5 REPLIES 5
perspective settings
sun
Dwight
I asume that you refer to the sawtooth soffit shadow???
What version of Archicad are you using?
IT IS ALWAYS A GOOD PRACTICE TO STATE YOUR SYSTEM WHEN ASKING A QUESTION BECAUSE THOSE OF US WHO ANSWER NEED TO KNOW THESE THINGS.
The panel you aren't sharing is the one with the Sun Shader found in the Photorendering Settings. If it is Archicad 10, and selected is the SUN:REALISTIC SUN shader, then you must double the samples.
Dwight Atkinson
render settings
yep that fixed it...sorry i had a few technical issues while posting the rest of the render settings...no need now...thanks
and yes...i am on AC10...i need to just put it in my signature like everyone else
