Visualization
Render your model with built-in or 3rd-party solutions
sketchup seems to kick archicads but for sun studies strange
Gus
I hope I am wrong, but does anyone out there know how to do what is so easy on Sketchup: showing shadow lines for a specific date and latitude using Archicad? It seems like it would be so easy, but I can't for the life of me find a way to see where the darn shadow lines will be from the roof edges and from the adjacent building. I'm using a Windows Version of Archicad 13
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
8 REPLIES 8
It's easy: Document > Creative Imaging > Create Sun Study...
You will want to go int the VIEW menu > 3D VIEW MODE > 3D PROJECTION SETTING and then press the MORE SUN button.
I am not sure if the North direction can be set here in version 13.
If not then that is in OPTIONS > PROJECT PREFERENCES > LEVELS & PROJECT NORTH.
Your adjacent buildings will need to be modelled if you want to see the impact of their shadows on your model (or vice versa).
Dwight
And: There's a trick where you render the sun study in LightWorks where the other buildings can cast colored shadows to differentiate their shadows from the new project's shadows.
We discussed this long ago. Uses the Shadow Caster Shader.
Dwight Atkinson
Gus
I've created sun studies in Archicad 13 already, but I want to see the shadows while I move around in the model. Also there are no shadows cast by the roof onto the walls and I can't figure out why that is the case.
Madison WI
Stress Co_
You'll have to get ArchiCAD 14 or VBE
Marc Corney, Architect
Red Canoe Architecture, P. A.
Dwight
Or revert to the painfully slow internal engine with cast shadows 3D view mode.
Dwight Atkinson
Stress Co_
....and you can't say they didn't warn you
Dwight
sho' nuff
Dwight Atkinson
