Visualization
weather preset
i have been trying to change the weather preset to change the sky but i can't i put another that is not clear and its back clear again someone know what i am doing wrong or what is wrong with archicad
16 REPLIES 16
yes the same happened to me, i download cinema 4d and there i don't have any problem changing the sky, i didn't want to use 2 programs when archicad should make the same work
vfrontiers
Seems like none of these settings are STICKING!.. Somehow FOG got turned on the SUN SETTINGS... I turn it OFF and start a rendering... 90min later it's obvious that FOG is still on...
Crap..
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
nobody has an answer for this yet??
ratnabhirud
Before saving a view from 3D window, check Cinerender preset setting set properly, close dialog box and then save current view.
attaching image for the same.
Regards,
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
yes and nothing yet =/
vfrontiers
My particular issue is that the changed weather parameters in the RENDER SETUP BOX do not apply to the rendering that I start immediately following the changes... (No SAVED VIEW involved)...
Duane
Visual Frontiers
Hi Team,
Just piping up as I am currently encountering the exact same issue as you, Gebrunn. Have also tried all of the other suggestions, but have had no success. Has anyone come to an answer to this issue over the past year?
Thanks for your time, much appreciated!
Regards,
Charlotte
