Aussie John
wrapped images to work in lightworks
I dont suppose this will get many comments but this definately should be fixed /improved upon.
1) Attach a photo image to a material and it shows backwards/upsidedown.
2) cant move its position relative to the element it is fixed to.
3) cant rotate
4) cant control tiling
Please fix
Id be pleased to find out I am wrong
Cheers John
[/size]
5 Replies 5
Rob
john,
at least the first one is a known bug, go to http://archicad-talk.graphisoft.com/viewtopic.php?t=7587 for a workaround...
::rk
Aussie John
Thanks Rob I'll look at that. Maybe this poll should go on hold
Cheers John
[/size]
3) cant rotate
Please fix
Unless I'm misunderstanding what you're going for; I was under the impression that you could move the position relative to the object, and also control the tiling method, see this thread: http://archicad-talk.graphisoft.com/viewtopic.php?t=8239
HTH,
dan
Dwight
While the OpenGL method is fine for local origin/direction solutions, a LightWorks surface is permanently altered using the Texture Space Class with St Layout Shader Parameters.
These modifications are not reflected in ArchiCAD's Internal Engine or OpenGL.
"LightWorks in ArchiCAD" Page 104 and other places, for those of you who already have the book.
Dwight Atkinson
Aussie John
Thanks Dwight - I have been waiting a while for a definative answer.
S*U*C*K*S the changes are only global
Cheers John
[/size]
