Hi all,
This wish is for there to be an Opening Line Type preview in the door / window settings dropdown, OR for the Type Label to be customisable.
AC30 introduced the ability to set and select Opening Line Types via your MVO Settings. The shortfall here is that there is no link between the Type Label and the settings it represents. The first suggestion would be the ideal resolution would be to have a preview included in the settings drop down, though that would require a new type of menu function as the drop down would need to display dynamic images rather than the fixed options currently available. The second suggestion would be easier to implement as the Type n Pen and Type n Opening Line parameters would just need to relate to a user customisable text paremeter. Parameter 1 instead of "Type 1".
Ling.
ps. When you have your own AC licence that no longer has permissions to post on the Wishlist... Zzz...
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
