Base Cabinet Counter Edge All Sides
The Base Cabinet Block should have the option to apply the Counter Edge Profile to all sides, not just the front.
6 Comments
Claudiu Serban
You know what's weird? The code is already there. You just cant enable it for the other sides. I needed like 2 minutes to enable it for the left and right side, using the Counter Edge Visibility. If you wish you can download it from the link below.
PS: I didn't link the back edge, but that can be achieved just as easily.
https://gofile.io/d/c1kQzTjz
Thank you, Claudiu. I wonder if this can be put into the next libpack update.
In the meantime, would you be willing to revise this to include the back edge too?
Florin Luca
Thank you, @Claudiu Serban. I downloaded the file, but I can only change the profile of the front edge still. I wonder what am I doing wrong? That said, would you be willing to share what line(s) of code did you actually change? Teaching a man to fish... that sort of thing!
Multumesc mult 🙂
Claudiu Serban
Did you check the edge visibility? that's how you turn them on!
Make sure the sides are checked and it will apply the profile for them as well.
About the code, its a bit odd as the object calls a macro (KitchenGeneralMacro), that calls another macro (KitchenCounterMacro), and that calls yet another macro (KitchenCounterTopMacro).
This is where you must work, but you need to modify them all to call your modified version (thats why its a library, not a single gsm file)
In the master script, lines 80 to 87
_bCounterEdgeLeft = 0
_bCounterEdgeFront = 1
_bCounterEdgeFrontLeft = _bCounterEdgeFront
_bCounterEdgeFrontRight = _bCounterEdgeFront
_bCounterEdgeRear = 0
_bCounterEdgeRight = 0
_bCounterEdgeRearLeft = _bCounterEdgeRear
_bCounterEdgeRearRight = _bCounterEdgeRear
replace with
_bCounterEdgeLeft	= bShowCounterEdgeLeft
_bCounterEdgeRear	= bShowCounterEdgeRear
_bCounterEdgeRight	= bShowCounterEdgeRight
As you can see, they were always 0, with no way to control them. I just linked them to the counter edge visibility, as most probably if you want it seen, it's an open edge.
Here is the updated version, with full control all on 4 sides.
https://gofile.io/d/YNcdLC1V
Thank you for the great information, @Claudiu Serban!
Hopefully the GS team will incorporate this fix into the next library updates.
Florin Luca
Thank you, that did it!
Yes, it would be good to have it done by GS, otherwise we need to do this after each lib update.
Status
Submitted
with 1 Vote
Wish details
