Ability to Represent Curtain Wall Sub-Assemblies as Separate Entities in Schedules
Gortz
Background
Currently, the Curtain Wall tool in Archicad consists of two levels:
  1. The entire Curtain Wall as one comprehensive element (including all panels, frames, and other components).
  2. All individual sub-elements (each panel and each frame separately).
There is no intermediate level that allows a specific sub-assembly (for example, a repetition of the scheme) to be handled and represented as its own entity.
Problem
  • 2D Plan Preview only shows the scheme, not the actual geometry of the real instance of the assembly in the model.
  • The Annotate function creates a drawing view of an abstract idea (the scheme), not of the real model geometry. As a result, users risk dimensioning and documenting information that does not match what actually exists in the model.
  • It is not possible to generate accurate elevations, dimensioned views, or labeling for individual sub-assemblies in a consistent way.
Request
Introduce a new hierarchy level in the Curtain Wall tool that makes it possible to:
  • Define a sub-assembly (a repetition or field based on the scheme) as a separate entity within the model.
  • Generate 2D Plan Previews, sections, and elevations that display this sub-assembly with its actual instance geometry, not just the scheme.
  • Dimension, annotate, and publish drawings of individual sub-assemblies without having to explode the Curtain Wall or use workarounds.
Rationale
Such a feature would:
  • Greatly facilitate the creation of assembly instructions and detailed drawings for individual fields or modular repetitions.
  • Minimize the risk of incorrect information in documentation.
  • This would allow you to list according to the following image, i.e. each repetition separately.
1 Comment
KevinJ
Totally agree this tool is bad, the lack of option in schedule is dramatic. Even the window or door don't show ! in plan and axonometry ... how did they expect to create document for builder like that ! I guess my way around will be internal elevation and manual editing !
I don't even understand how other user manage that. Right now designing office, I have 50 + different wall to manually annotate !
Status
Submitted
with 3 Votes
Wish details
