Auto-Rebuild Details & Worksheets
J_Tucks
Don't know how this is still not a thing. Why do sections and elevations have 'Auto-rebuild' and 'Manual rebuild' where as details and worksheets are converted to dumb fills and lines??  This means you essentially can't add detailing like dimensions, labels or annotations to a floor plan callout with out checking it every time a change is made on the associated floor plan. Making them consistent with floor plans, sections, elevations should be a simple fix and a huge benefit to users.
Additional info:
I've seen work around for dimensioning by using hotspots, as listed here: https://community.Graphisoft.com/t5/Design-forum/detail-auto-rebuild/m-p/124760
This is a horrible workaround as your dimensions are not linked to model elements and do not update accordingly.
Our current work around is also horrible. We place a worksheet marker on the drawing, then save a floor plan view at 1:50 and place a 'background fill' around everything except the worksheet callout boundary. We then have seperate layers used for dimensioning that callout. Its messy, you can't have callouts close together, and display orders also become an issue.
28 Comments
Agree, auto-update option for details would be nice.  I'm trying to understand the mask request... vs the bounding rectangle that defines the detail? Or... using the pet palette to re-shape the default rectangle into whatever shape you want to capture the detail area?
DGSketcher
Legend
I think Live Details is somewhere in the many wishes we are waiting for...
gdford
yes - I know it has been wished for by many including myself.
Just trying to keep the ball rolling...
gdford
Well - yes it would be nice if the bounding rectangle of the marker defined the area of the mask so the live detail was cut out in the same way the static details are cut... I just assumed it would be easier to implement  in a more manual way.  I don't really care how the mask is implemented as long as it has one and it is adjustable. I think version 27 would be a good time to release this improvement.
scottjm
Mentor
This is an absolutely essential feature. The elements should be the native element, (like in a section/elevation not just a 2D exploded that was constantly updating). So then you can label the elements.
We would use this all day everyday for 1:50 individual room layouts. The current worksheet workflow for room layouts is ridiculously painful and frustration.
J_Tucks
You'll find this in the wishlist a few times but not on the roadmap. Not sure Graphisoft agree with us on this one.
gdford
I noticed this was not listed on the roadmap - but the roadmap appeared to be out-of-date.
I always hope for updates that help me do my job, rather than updates that make a good sale pitch but then peter-out into nothing of substance in my day-to-day practice.
SeaGeoff
Ace
This wish has been around as long as the Detail and Worksheet tools. It was commonly called Live Worksheet in the past. I know from prior conversations with folks at Graphisoft that they are well aware of the value of this feature (or set of features) and its long history as a crowd favorite. That it is NOT on the roadmap is a mystery. To me this development is in the top 5 overall.
scottjm
Mentor
Bumping this for spring clean wishes as I believe it is one of the most important features we need in Archicad.
This will make producing room layouts and details so much easier.
The current worksheet workflow for room layouts is totally unworkable.
Laura Yanoviak
I agree it would be nice to have a better workflow for enlarged plans.  We currently use Barry Kelly's method, and I've recently thought about using Design Options for the same purpose.
I don't agree that details should be live, unless there is an option to keep them independent.  Live details in a large office could have catastrophic consequences.
Status
Upvoted
with 63 Votes
Wish details
Product
Labels
