Auto level dimension a mesh
JamesatVIP
Add the ability to space click or auto dimension all the spot levels on a mesh using the level dimension tool.
Currently there is no way to see where the spot levels are on a mesh unless you go into the settings, turn on the "show all contours" option, then place all your level dimensions 1 by 1, then go back into the settings and turn the contours off.
The alternative is to just select the mesh to find the nodes, then hover the mouse over a node, hit esc to deselect the mesh, then click with the level dimension tool active.
Some way to hold space bar and have it auto dimension all the spot levels would save so much time when added up.
Or even a label that could note the height of the node so you can use the auto label tool or something.
1 Comment
BernardMaree
Would be super useful, something similar to that of Revit. The mesh can then be used to make paving layouts and screed layouts rather than roofs etc. Would help a lot when designing or checking Engineer's drawings.
Status
Submitted
with 1 Vote
