Batch Add/Remove properties from Interactive Schedules
Erik Bjornhage
It would be great to be able to add/remove properties from more than one schedule simultaneously.
Yes, I know we still have to open the schedule to drag it to the right place in the list...but even the first step would be a time saver.
Perhaps this could be done with AI Assistant - but since I can't add the wish to two different products (above) it has to sit in the Archicad category only.
3 Comments
James B
Hi @Erik Bjornhage
Can you elaborate on an example of the types of fields you’re trying to remove from multiple schedules? And why they were added in the first place? Thanks.
Would like to understand the workflow.
Erik Bjornhage
We (at work) were discussing work flow where you have to customise schedules for specific clients or where you have added a new property that you want listed in several schedules.
We also realised that you still need to go into each schedule to re-order the properties if required.
But to be able to just batch add would remove one or more steps and we felt it could save time.
Not sure if schedules could be done in a completely different way down the track...but it could be worth exploring.
James B
Thanks for clarifying @Erik Bjornhage clearer now.
Status
Open
with 2/200 Votes 100%
Wish details
