Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Be able to add a lower door frame with the door tool
_emilien_
There's one option I find essential in ArchiCAD that I don't see : the ability to add a lower door frame with the Door tool.
Indeed, this option isn't available in ArchiCAD, even though it would be very useful for creating entrance doors. So I have to create them with the Window tool, which is less suitable.
If you can solve this problem, that would be great !
Thank you and good luck.
Émilien
8 Comments
Have you tried the option for 'Threshold'?
Or 'Sill' which is a little different and not exactly what you want I don't think.
_emilien_
With the door tool, I only have a frame at the top, even I use a threshold. But if I use the window tool it's ok but it's less appropriate. And I think it's possible to have a lower frame with the door tool.
At the left it's the door with the door tool and at the right the ''door'' with the window tool.
A hinged door does not usually have a frame at the bottom, just the threshold or sill, which is usually quite low.
The door leaf itself can have a frame.
Is that what you are expecting to see?
_emilien_
Ok that's what I thought !
Émilien
I have never seen a frame at the bottom of a door frame (except for a sliding door).
If you want me to leave this wish open, I will, and maybe one day you can have the option for a bottom frame.
Otherwise if you are happy that there is just the threshold, I will close the wish.
_emilien_
For an entrance door I use a frame at the bottom of a door frame, not you ?
You can leave this wish open for that !
I will leave the wish open then.
For me a metal or timber threshold (like this), but not an actual frame.
_emilien_
Okay I think it's an other way to build.
Thank you for your time !
Émilien
Status
Open
with 0/200 Votes 0%
Wish details
Labels
