Bring SketchUp file format to the Organizer - Publisher
Laurentiu
💡 I have a fairly simple wish.
Bring the SketchUp file format into the Publisher so we can automate exports of SketchUp files.
💾 Right now to save a SketchUp model from Archicad you need to:
1. Open up a 3D View Point
2. Go to File > Save As...
3. Select the Location, choose a File Name, select a File Type and click Save
4. Choose the Export Options from the dialog box, most importantly the SketchUp Version.
5. Click OK.
⁉️ That's like 10 unnecessary clicks.
⚙️ I would rather set up a 3D view in the template, bring it in the publisher set, and set the export options.
This would ensure that the model is always exported in the desired SketchUp version, together with other items, in an already set location, all with just one click.
👍 Below is a mock-up of how I see it.
edit: Added some emoji, because why not.
2 Comments
Bohdan Ratushnyi
I need that! 😍
Jakub Nohejl
It cloud be also .FBX 🙂
Status
Open
with 25/200 Votes 8%
