Allow all GDL-object related parameters/attributes to be changed via Property Values/Excel
Do you mean "including Library Part Parameters"?
In 28 with global libraries we now have value mapping.
Hi @Barry Kelly,
Do you have a link to an explanation of the value mapping?
@Ruben V - I mean being able to update all (windows, doors, and any other type) objects parameters not only their properties.
https://graphisoft.com/resources-and-support/downloads/?section=bim-content
It is all a very manual process at the moment, a tool is supposedly be created for version 29.
Search these forums also and you should find other posts about it.
One example ...
https://community.graphisoft.com/t5/Installation-update/How-to-use-the-Mapping-Values/m-p/639788
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 13/200 Votes 15.384615384615%
