Clean up composite skins through empty openings and wall ends without messy workarounds
Paul King
Mentor
Please allow composite skins to heal though empty doorways and other openings, and at wall ends - as an intrinsic part of the wall, not requiring messy workarounds and wall end objects.  The workarounds all fail in one way or another, with unwanted outcomes either in 2D or 3D.
Please ensure these just skins clean up seamlessly with the skins of other walls that intersect adjacent to openings.
Cleanup of composites (including with skins healing through holes) should work in section as well as plan, without extra effort, and without the current workarounds or compromises.
All composite elements should work and clean up this way, without the huge time wasting overhead involved to 'fool' the model into displaying what it should logically display by default in all views
3 Comments
Works for me just fine.
In the Composites Dialog, make sure that skin end lines are set to be shown.
Paul King
Mentor
Hi Laszlo.  You seem to be referring to the single line just showing end of framing core, not the double lines and fills that outer skins need to show when wrapped across to close off the end of the core through an empty doorway or opening
Yes, you are right. Sorry, I did not zoom in onto the screenshot and I did not see those additional skins.
Status
Open
with 8/200 Votes 25%
