When entering edit mode in a curtain wall, every change of the curtain wall scheme in a 2D view requires a rebuid, before the ability of moving scheme lines is active again - even with all geometry turned off.
Step 1 - move a scheme grid line
Step 2 - try to move another scheme grid line without rebuilding your model...
At least for this situation - when all geometry is turned off - this requirement of rebuilding should not exist. It costs a lot of time and is also very annoying.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
