Curtain Wall - Edit Scheme rebuild after every change
2D
When entering edit mode in a curtain wall, every change of the curtain wall scheme in a 2D view requires a rebuid, before the ability of moving scheme lines is active again - even with all geometry turned off.
Step 1 - move a scheme grid line
Step 2 - try to move another scheme grid line without rebuilding your model...
At least for this situation - when all geometry is turned off - this requirement of rebuilding should not exist. It costs a lot of time and is also very annoying.
1 Comment
DamianW
Yep, some custom editing commands should always be able to maintain a connection with the scheme.
It shouldn't be that hard to maintain panel customisation while editing the scheme.
Status
Open
with 0/200 Votes 0%
