Design Options - All Design Options within the same Design Option Set visible
Joostm
We use Design Options to create different modules that we then insert into the main model.
Wish: be able to turn on/visible all the options in 1 Design Option Set
Why: now you can only have 1 Design Option visible per Design Option Set, which means we have to create different Sets for each module, so that we can turn all the options/modules on. if we could turn all options everything on it would make it way easier to manage all the options and their Sets.
4 Comments
Joostm
another advantage of being able to do this is to see multiple options in 1 schedule. right now its not possible
Hi @Joostm ,
I consider you didn't give a try to the design option combinations yet, kindly see the below attached Screenshots.
Screenshot 2025-02-26 144717.pngScreenshot 2025-02-26 144713.pngScreenshot 2025-02-26 144703.png
Joostm
hi @Mahmoud Qenawi
i did.
Placing it in folders/new option set is exactly the workaround I use.
my wish is to have all design options visible in one folder, so you end up with way shorter lists and also visible in 1 schedule.
Status changed to: Open
I don't understand why you would want to see all options at once?
If it is bathroom option 1, bathroom option 2, bathroom option 3, then you surely you would want to see option 1 OR option 2 OR option 3, not AND.
The same for scheduling, you would want 1 or 2 or 3, not 1 and 2 and 3.
Separate design option for different areas, yes you would want to see at the same time, bit this is why you put them in different option sets, sp you can have them active at the same time.
Status
Open
with 5/200 Votes 40%
Wish details
Product
Labels
