Display Order, Option to place newly created elements on top
Kleopatra
When a project uses a deliberately customized Display Order, newly created elements may appear behind existing elements that have previously been brought forward.
This means that a newly created line, fill, dimension, text or other 2D element can be hidden immediately after creation, making it difficult to see, select and edit. The current workaround — manually using Bring to Front after creation — is repetitive and interrupts the drafting workflow.
I would suggest adding an optional setting such as:
“Place newly created elements on top of the current Display Order”
When enabled, a newly created element would be placed above the currently existing display stack at the moment of creation, while all existing relative Display Order relationships would remain unchanged.
2 Comments
Andrei D
Hello Kleopatra,
I would recommend to ask for an option to Set display order level within the settings of the element. I have "inherited" projects that had a lot of elements at the top level and it was a mess to work with.
Have a nice day!
Guru
Yeah, you really do not want to give people to ability to simply put things on the top level. It is already a nightmare finding all of the elements that people Bring to Front without the added ability for users to make that the default...
Here is a wish for what Andrei has referenced: https://community.graphisoft.com/t5/Wishlist/Improve-Control-of-Display-Order-Stack-Levels/idi-p/712...
Ling.
Status
Submitted
with 3 Votes
Wish details
Product
Labels
