The current UI does not make sufficiently clear that “Home Story” does not guarantee visibility on that story when “All Relevant Stories” is selected.
A wall can have Home Story = Ground Floor, extend entirely below that level, and consequently appear only on a lower story. This behavior may be internally consistent, but it is not transparent from the settings dialog.
Suggested improvements:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
