Proper classification and control of a BIM project is very time-consuming. Assigning values through drop-down menus often requires too many clicks, and using Graphic Overrides to control and visualise each property in the drawing can be extremely inefficient.
A dedicated dockable palette for classifications and properties would be a much more practical and efficient solution. In addition, having the option to automatically visualise the values of a selected property directly in the drawing would be a huge improvement to daily workflows (I am aware that an add-on exists for this, but native functionality would be far more robust and accessible).
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
