We have projects where we need to model everything in great detail so the contractor can calculate the m2 of materials he needs. Example: m2 of plasterboard around an opening or m2 of a complex profile plate.
When you open a model in solibri the m2 is usually not accurate. I find myself having to model everything separately ( 2 walls + 1 slab) or adding formulas to properties to make the m2 +/- accurate.
It would be save a lot of time if one could define the perimeter that should be calculated for the m2 of the element. (red Line) inside the complex profile for instance.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
