Elements m2 on bim softwares
Joostm
We have projects where we need to model everything in great detail so the contractor can calculate the m2 of materials he needs. Example: m2 of plasterboard around an opening or m2 of a complex profile plate.
When you open a model in solibri the m2 is usually not accurate. I find myself having to model everything separately ( 2 walls + 1 slab) or adding formulas to properties to make the m2 +/- accurate.
It would be save a lot of time if one could define the perimeter that should be calculated for the m2 of the element. (red Line) inside the complex profile for instance.
2 Comments
Status changed to: Submitted
Have you tried using a 'surface' schedule rather than an 'element' or 'component' schedule?
Joostm
i have seen the Contrabim tutorial and i do see it works accurately in schedules but my point is in the m2 that you get as an surface area when you open the IFC model with solibri/bimcollab.
There the m2 are not accurate so it leads to the mentioned solutions that make it very un efficient
Status
Submitted
with 0 Votes
Wish details
