2D fills using the Fill Category: Cover Fill do not count as actual Cover Fills...
Can you elaborate a bit more on this?
When you say "do not count", do you mean that they currently do not count but they should, or that they currently count but they should not?
And in what context do they count/not count and shouldn't/should? In Area calculation? Schedules? DWG/DXF export? Something else?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
