I'd like to be able to put spot heights on a beam when it is sloped.
Alex4hout
When denoting a sloped beam—a round one—the spot level of that beam should be able to select the reference line. So if the reference line is set at the lowest part of the beam, a spot level along that reference line will read its true height. See, I'm in need of this for drawing civil pipes. I don't want to redraw the pipes with a roof, etc., due to the gravity snap. Also, when moving the beam, the snapped gravity-placed level should move with it.
Status
Submitted
with 0 Votes
