Hi There,
For lists on a layout, there is a feature called "split drawing among multiple layouts." This function ensures that you only format the layout once and position your list correctly on it. Subsequently, Archicad generates multiple sheets until the entire list is used. I would also like to use this feature for detail markers. That way, you can position one detail correctly on your layout and print all details as a booklet in one go. Perhaps a function could also be built in allowing you to select which details are included and which are not, so that you can incorporate standard detailing into your Archicad template.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
