Import attributes with appropriate folders
rakurs
When importing attributes via Attribute Manager, every attribute should be imported together with its folder, ot at least there should be a check-box. I have attributes organized in folders, but when I import them, the file that the attributes are imported into has them all in its root folder. It's not as much as a feature wish but a consistent implementation of a feature.
4 Comments
You are aware the Attribute Palette has the option to import folders?
The Attribute Manager was around before folders were developed, and the Attribute Palette was meant to replace it.
But I agree, the Attribute Manager should also include folders, as I still prefer the Attribute Manager.
rakurs
Woah. So there is that option. Okay, I'm obviously using the wrong tool. But going back and forth between module and site file is tiring and cumbersome already. I'll try the palette.
rakurs
Wow, thank you. It works. Unfortunately, it didn't completely clean up my site file when re-importing but it will work from now on. I had no idea that there was an obsolete tool.
Status changed to: Closed
The capability already exists in the Attribute Palette.
Status
Closed
with 1 Vote
Wish details
Product
Labels
