One of the things that can be quite frustrating and time consuming is not having a quick way to know where something was put at and the nature of existence to the whole model, and one of the best examples is the Hotlink Manager.
When you insert a Hotlink to the model, the program will ask you for the Master Layer, and ID, which is fine, but when you have to quickly check which Layer was used to put the Hotlink using the Hotlink Manager, it simply does not mention neither the Master layer that was used nor the master ID that was given, and to query a whole model for this data, by turning on/off layers one by one, is time consuming.
I wish that the Hotlink Manager to:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
