Improving control of wall ends in 2D and 3D
2D
The way the 3D geometry and ends of a wall behave at the moment give the user insufficient control over the outcome.
  • It would be a great improvement if the wall ends could be adjusted - in 2D to match for example a non-orthogonal slab edge or in 3D to be able to adjust the heights of the wall ends individually
  • additionally the possibility to add control points along the upper edge loop - similar to a certain degree to how you add control points to a mesh object - would further enhance the user friendliness of this tool
For now all above mentioned points can be achieved via the wall end tool - if it is not a complex profile or composite wall or by using SEOs
1 Comment
GG_rakurs
Many, many, MANY improvements are needed to the wall end tool, and general behaviour of walls when they end or change composite / thickness.
Status
Submitted
with 11 Votes
Wish details
