In-Place Hotlink Edit And Management
PSW
14 Comments
Angel Berruezo
@Barry Kelly
Depending on how many hotlinks you have or need, you may end up with an enormous list of floors in your Navigator. I use the iceberg method for entire floors or dwellings. For smaller elements, I usually draw the object in place and then save a MOD file manually. As I mentioned, we have been discussing this point for years, and it has already taken far too long.
Casper
@EmmanuelF Why can't there be interaction? With the current module approach - placing .mods or .pln as modules in your main model - there is also interaction between elements. And most of the interaction is based on intersection priorities and layer intersection group numbers, which are global settings in your model/file.
EmmanuelF
@Casper Yes, with the current system this interaction exists (although it does not work very well). But if you replace the current modules with a block system (as in AutoCAD, SketchUp), it would be lost (I suppose).
There are numerous wishes all about modules, just scattered around in the wish list under different names.
These should be combined into one wish and add all votes together. That way maybe GS would recognise the importance!
Make Modules Great Again!
Status
Open
with 51/200 Votes 3.921568627451%
Wish details
