My wishlist item for today, would be to allow whatever the Text Label shape is for my Keynote on the floor plan to show up as well on the corresponding item (number in our case) in the Keynote Legend on the Layout. For instance, I have a 1 with a circle around it on the floor plan. Put the same circle around the 1 on the Legend on the Layout. That way if there are multiple label shapes on the floor plan, there is an easy graphical cue as to which keynote legend the viewer should be looking at.
We're still evaluating if the new Keynote feature is beneficial to our firm and that would certainly push it in the positive direction.
Thanks!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
