Smarter Module Management: Define Your Own Anchor Point
Klaasnorg
Let’s rethink how we work with modules. Right now, modules always reference the drawing’s origin point, but how often is that actually helpful?
What if you could define your own anchor point when creating a module? Snap it to something meaningful, like the intersection of two gridlines, and that spot becomes the module’s reference. Placement becomes intuitive and precise, no more offset tweaking, flipping or endless adjustments. Just click, place and move on.
It gets even better. You can edit any placed module directly, right where it is. Save those changes under the same module name, and all instances across your project update instantly, no position shifts, just smarter updates. Everything stays where it should, but reflects the latest design.
The best part? It’s not just cleaner, it’s faster. No more repetitive work, no unnecessary re-placements, and no need to hunt down every instance manually. It’s a huge boost in efficiency, especially in larger, complex projects.
The result?
✔ Smarter, faster workflows
✔ Fully editable, in-place modules
✔ Seamless updates across the board
✔ Clean, consistent designs
✔ And no more origin-point drama
Design with freedom, edit with confidence, and work way more efficiently.
It’s time to anchor your modules where they actually matter.
Status
Submitted
with 32 Votes
Wish details
Product
Labels
