Layer organization and UI Improvement
Space_Agency
Problem:
Because layers are fundamental to 99% of all architectural projects, the layer UI (when it is on, how folders work, etc.) needs to be improved. It is cumbersome in process and needs improvement to be quicker and more effective.
Scenarios and use cases:
1. Layer folders have no dropdown ( we have to open the folder to see the contents as opposed to being able to click on the folder and the layers within the folder drop down to be seen).
2. Layer dialogue box has to be opened to modify layers and layer combinations. we have to open the layer dialogue box to modify layers (turn on/off, organize into folders, rename, etc.) This should simply be a UI panel similar to the info box/design options, etc. that we can turn on or off in the UI/work environment such that is available while we are working and do not have to stop and open the dialogue box.
3. Layer Combinations should have the same behavior with folders and dropdown capabilities of those folders. This should also simply be a UI panel similar to the info box/design options, etc. that we can turn on or off in the UI/work environment.
4. Also, the little eye icon turning on or off to indicate if a layer is in a combination is not visually significant enough. Instead just highlight the combination in the interface if the layer is in it with a change in background (light/dark) behind the layer combination text.
Please focus on making it less cumbersome to work in Archicad
Status
Submitted
with 1 Vote
