Let us add multiple surfaces from Additional Surface Catalog
cocoloco
Just working on new project, had to proceed with anotherrrrr download for additional surface catalog, and add into the library.
What I expected: all the surfaces are now in the file (since I added it into library and the size of the library reflect it, right?) and that is it, ready to go to modeling and select whichever new surface I want.
What I got: thousands new surfaces grouped in folders, with option to add one by one at the time. You need to MANUALLY select which surface you want, you can't even multi-select.
Glad I did not have to add one by one also the rest of library items.
Am I doing it wrong? Could someone wish with me please?
1 Comment
NBGheikki
Barry Kelly has a workaround for importing multiple surfaces: https://community.graphisoft.com/t5/Visualization/Additional-Surface-Catalog-for-Forward-and-SSA-Use... . But this is also a bit tedious since you have to import the surfaces on a new project and then use attribute manager to get them (because the command to import all surfaces will delete the current list).
Status
Open
with 3/200 Votes 66.666666666667%
Wish details
