Locally Define Cut Planes
TaniavH
We need the ability to locally define a custom cut plane.
Graphisoft needs to provide a solution for story settings for multiple buildings with different floor levels, or buildings with multiple floor elevations on one story. This could potentially utilize a polygonal Marquee to define the area of custom cut plane, or something similar.
  • The current workflow for multiple buildings at different elevations requires MODs.
  • The current workflow for multiple floor elevations on a story in the same building requires view-based custom cut planes, which do not always work with cutting through fenestration – setting some walls to symbolic cut is time consuming and doesn’t necessarily fix the issue in all instances and can provide unwanted graphical issues.
  • Optional (even less efficient) workflows require PMK creation for portions of the building which are then placed in plan views, or alternatively saving separate views and stitching them together on the layout.
1 Comment
AngelWil
We need a way to Dynamically control the plan cut plane. We have building steps in many projects and stitching together plans views leaves room for error. Its also tedious to set up. I would think the best solution is using a similar tool to the section viewport that allows you to manually draw the level you want the cut to occur.
Status
Submitted
with 11 Votes
