When two or more walls intersect and are joined, the connection should remain associated when the geometry of one of the walls is then edited.
Currently, if the end of a wall is stretched, shortened or moved, the wall can become disconnected from previously intersecting wall(s). This means the connections need to be manually re-established after relatively simple geometry changes.
It would be highly useful if ArchiCAD could be smart enough to recognise and maintain these wall connections as relationships.
For example, if the end of a wall is moved, any walls that were previously connected to that end should automatically adjust and remain connected where possible.
This would make editing wall layouts much more robust, particularly in larger projects where many walls intersect, and reduce the need to repeatedly clean up and reconnect walls after design changes.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
