Make Modules Great Again - 5: Modules Source Storey
Mod files should not remember what was their source storey.
Why?
If someone uses the Iceberg Method, meaning the module is created in the source file on a negative storey,
if a new storey is inserted between 2 existing module storeys, the whole model gets messed up.
Creating modules in negative storeys may still be relevant even if Make Modules Great Again - 1: In Place Module Management was implemented.
Refer also:
Modules: required improvements
Make Modules Great Again - 2: Embedded Library Management
Make Modules Great Again - 3: Attribute Management
Make Modules Great Again - 4.0: Schedule Modules
Make Modules Great Again - 4.1: Schedule Mirrored Modules
Make Modules Great Again - 6: Labels in Mirrored Modules
2 Comments
Ernest Atanasiu
I would like to have "special" stories that host only modules like a hidden iceberg. Many times I had someone add an extra story between 2 existing modules and mess up the whole model.
Yep, special  storyes may have the same effect as what I wished for, however, I think tha if mod files simply don't carry the source storey info, that would work too. Probably easier than creating special storeys.
Not to mention the best solution which is in place modules.
Status
Submitted
with 34 Votes
