More Plumbing Objects that are working with the "All Relevant Stories" Floor Plan Display
Andras Bognar
So far a handful of Plumbing Elements (from the default Archicad 27 Library) are working well with the View's Floor Plan Cut Plan Floor Plan Range if we use the All Relevant Story Floor Plan Display settings and they are 1 story above.
The goal that we try to achieve is to have a MID-Floor Framing Plan View made from the Ground Floor Story so we can see the Doors and Windows from the Ground Floor and place the MID-Floor Framing Object or Beams on the First Floor with Show Home+1 Down. The Plumbing elements (sink, toilet, shower tray, drain etc.) in the Bathroom and the Internal Walls on the First Floor have the All Relevant Story Floor Plan Display.
In this case, we can set the MID-Floor Framing Plan View's Floor Plan Cut Plan Floor Plan Range to see above and the Relevant Items should show up. But not all of the Plumbing objects can do that. The Urinal 27 the Basin 27 and the wall are doing the job. But the Toilet and the Shower Tray don't do it.
The following Plumbing Objects from the default Archicad 27 library are working (green) and not working (red) in this scenario:
Status
Submitted
with 0 Votes
