More bowl configurations within "Toilet ADA" object
Brandon-W_DWa
Problem: "Toilet ADA" object has only floor mounting and "Cistern" Flush Types available; no option for Wall Mounting, or any of the other Flush Types that are available to the "WC" object.
Scenarios / Use Cases: The "Toilet ADA" object allows USA users to save a typical ADA water closet favorite, but only if the toilet is floor mounted and has a cistern. If the toilet has any other configuration, users can't use the "Toilet ADA" object, so instead have to manually place the "WC" object and three (3) grab bars, and make sure they are placed in the correct location to meet building and accessibility codes.
Wish: That the "Toilet ADA" object would have all of the same bowl options that the "WC" object does.
Status
Submitted
with 2 Votes
