Option to preserve 2D Fill orientation in Graphic Override fills
pejotunb
Currenty, when we choose to apply a fill from a Graphic Override, it will be shown at the default orientation of the fill, ie. it will disregard any manually set origin and rotation and scaling of the fill it replaces.
I can of course see a purpose for this behavior also, but probably more often than not, if the fill origin, rotation etc. has been manually edited, there will be good grounds to preserve it also when the fill pattern changed with a Graphic Override.
Could we have an option to select, whether the Graphic Override fill will follow whatever is set for the object's fill orientation settings?
1 Comment
Guru
Good to see that a wish that befell the Great Purge was revived.
Status
Submitted
with 7 Votes
