Option to show the fill for the beams when they are overhead
Leire Bilbao
When doing a Reflected Ceiling Plan (RCP), I usually need to show the finish of the beams as well as the slabs or the ceilings. Even would like to show the colour or different fills if they have different finishes.
Also sometimes you have different heights for them and you struggle to have a common cutting plane for the whole floor to show all objects with the fill and still cutting the walls at the correct height.
Even when we use the beam tool for other things it is useful to have the flexibility
Status
Submitted
with 1 Vote
