Parametric attributes
ClovisF
Introducing GDL, Python or any form of development language in the attributes such as composite, complex profiles, lines, (and basicaly every kind of drawing attribute) would greatly increase both the technical, and graphical abilities.
For exemple, a parametric complex wall with the same GDL API as the object could get the MVO and scale, and merge certain layers of the wall to make a more unified wall. Such as having a fully detailed wall at 1:20, and not having the separation for the plaster but only represent the isolation and core at 1:100 while maintaining the same thickness.
There is proof of feasability as it can be partly done with the accessories addon. A proper integration and update of the extension in the base software would be a bliss.
1 Comment
runxel
Basically LoD / LoG for profiles. That would be very great. I'm pretty sure there is already a wish for that, but meh... the search function does not help.
Status
Submitted
with 7 Votes
Wish details
