With today's BIM requirements, engineers and architects are asked to each have their own IFC model with only the elements relevant to them.
In this case, for the “architectural” parts, we are asked to export our IFC model without the structure and other technical lots.
However, when we use composite elements with finishing/technical and structural layers, we can't separate them from the “core” layer, in other words, the structural part.
We're therefore obliged to create structural materials dedicated to load-bearing elements (“STR wood”, “STR concrete”, etc.) and replace them with “empty” material each time we export an IFC, then go back and replace our load-bearing materials. This method is by all means functional, but very artisanal and time-consuming.
However, we have noticed that there is a “partial structure display” function that filters the 3D layers of the model, allowing only the structural elements and load-bearing “cores” to be displayed.
We'd be interested in having the opposite function of this setting: filter and hide only the structural parts and “cores” of elements, so as to have only an architectural model visualization that can be exported to IFC (finishes, cladding, doors, windows, ceilings, etc.).
And just to be clear, we're french and this was translated with DeepL.com (free version), so sorry about the possibles english mistakes.
Thank you for reading and even more if Graphisoft realise this wish
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
