Hi all,
I would like to be able to link a Licence to a GSID rather than to a Company.
The ArchiCAD licencing system has always been convoluted, and I recently found out that licences cannot be linked to a GSID, only a Company. So if you have your own licence, you are required to have multiple GSIDs in order to join a company. For the general user, this is probably not much of an issue as you just log into AC and forget about it, but if you are managing licences you then need to constantly switch between accounts... So much for "your digital master key"...
Ling.
ps. I have ZERO expectation that anything will ever happen in regards to this topic...
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
