It would be great if for placed DWG/DXF or any other data format which allows the usage of layers in the Drawing's own Layers menu it would be possible to:
One case example below:
When you want (read as need) to import Geodata in DXF from publicly available sources, it usually comes broken down in patches (rectangular areas). If you are unlucky enough and your plot just happens to be on the intersection of a couple of such patches you quickly run into the above mentioned problem. If you want to isolate specific features - such as streets or plots - you will have to manually go through the different placed dwg's and carefully select the same layers per entity...
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
